freeisforme
- Joined
- Mar 23, 2009
- 184
I've been watching here for some time before joining, so this is my first post here.
I've read all the horror stories about water logged boats and pretty much anticipated having to go through some major repairs on my latest find, a '72 Starcraft Capri trihull.
First off, the boat looks to have been super well kept, it came from a barn, with apparently very little use on it. The interior was more dryrotted than worn or faded, and the hull and transom so far seem bone dry. What I do have is a crack in the wood deck, it looks to have 1/2" plywood run crossways, with a seam ever 4" and a very thin layer of glass and resin. It's all done in color, which matches the boat, so I am sure it's original.
The last seam, which falls just below the front edge of the splashwell, is separated, I can lift the panels apart enough to get a lit mirror down inside, and I see no foam, nothing, it appears as if they just glassed the bare edges of the plywood together and used a few small clips to keep the edges secure? The stringers are intact, but I see no under support for the edges of the plywood, not there or any other joints. It almost just looks like the edges just broke apart or what ever was used to attach the seam gave way. The rest of the floor is perfect, solid as a rock. But I'd venture to bet if I stomped my foot on any of the other seams, they would also break apart.
Does anyone have any experience with one of these boats?
Does what I describe sound familiar?
I would bet money on the fact that if I could resecure the two panels as one again all would be fine with a fresh coat of glass and resin on top. There is no rot in the plywood, no sign of rot back in the bilge where the bilge pump sits, and the transom core sample is mint.
I was very leary of the transom since someone had installed a huge polished stainless panel under the motor, but after removing it, I see nothing but some glue stains where they stuck it to the transom. The transom was never drilled, and the hull is perfect in every other way.
My goal is to reoutfit this boat as a fishing boat for river use, I plan to remove all the interior, leave it as bare bones as I can, make the deck as hose down cleanable as I can, and add a casting deck where the two bowrider seats are now. The motor is came with runs fine, a fresh impellor and a set of plugs should keep it going for a long time. Here's a pic from the ad I answered, I'll get some new pics as soon as we get a good sunny day outside for me to pull it out and start working in it.
