hello all, i have spent some time reading on this forum about floor repair and i decided i would go ahead and repair my floor. I have a 99' Maxum 1800 and the floor around the "live well/anchor locker" has rotted/broken away. I have the carpet up, so now all that is left is alot of glue residue and the top layer of fiberglass from the factory.
i hope these pictures work...if not i will try to edit it...my plan of attack is to cut out a square section of floor roughly 4ft in width and 5ft in length and replace that with good wood...the red lines in this photo represent my cut
<br/>
My concerns are that i dont know where the stringers are, which way they go, or where to cut in order to tie them into a stringer so that the new and old wood meet on a stringer...is this even possible?
also i will be cutting at a 45 degree angle to facilitate matching up better.
Do i just go for with a skilsaw and see what happens?
Also will a regular purpose saw blade cut through the fiberglass?
Some more pics:
also can i remove glue residue with a belt sander?...or will that just melt the glue?...otherwise i will use a cup wire brush on a grinder
any and all help would be greatly appreciated
<br/>
Some more pics:
