Dave Turner
Thread starter- Joined
- Mar 7, 2006
- 118
Bought this Stratos with 96 115 Intruder that been setting for awhile. Cleaned the carbs and then drained the tank. Put new gas in when i pumped the bulb up i had a seal leak on the top of the vapor separator. Replaced that gasket and pumped up the ball and had a leak where the fuel pump fastens to the bracket. I can not believe they use 2 o-rings for a seal to keep gas from leaking there. I looked at diagrams and do not see any other seals or o-rings that would stop gas from coming from there. Do these 2 o-rings actually keep the gas from leaking from that nipple? Anyone had any experience or any info on this? Tight lines and no leaks, Thanks
