1960 evinrude 40 hp lark 2
wcast
i have a 1960 40 hp lark 2 electric start, someone needed my gas tank more than i did. can anyone tell me what size fuel line does it take? i have found 3/8 inch line with different size connectores. any body tell me what set up works for this motor? i have also lost the grounding screw that goes through the pigtail and into the motor any info on this would be greatly appreciated.
samo_ott
Re: 1960 evinrude 40 hp lark 2
You can buy the fuel line with bulb and connectors at both ends at any wal mart, auto stores, etc. They are the same for all johnson/evinrudes for 40 years or so... they're not expensive either... $20-$30...
wcast
thank you they have different size gas lines and connectors, didnt know if this would make a difference? what model or size spark plugs does this engine take and the gap if you know? thanks
F_R
5/16" gas hose. Champion J4C spark plugs at .030" They'll try to sell you J6C plugs. They'll work, but they are a heat range hotter than the J4
and you need the connectors for the Johnson/Evinrude.
jasper60103
All I see is 3/8" gas hose assemblies. I only checked walmart and couple other places though. I think you may have to make your own 5/16" gas hose or order online.
wcast
thank you to all that have replied i really do appreciate it.
