PiratePast40
- Joined
- Mar 21, 2009
- 1,734
Reading conflicting opinions about bracing the hull when removing the stringers. Boat is a 1977, 18' Fiberform runabout with a Volvo I/O motor. The boat is on a trailer with rollers. I intend on finishing up the transom ripout tomorrow. The stbd side upper part is good wood - dang if that isn't a bugger to get out!
Hopefully, I'll be ready to put in the new transom this weekend but woried about the next step - the stringers. Basically, I pulled about 1/3 of each out by hand after cutting out the glass at the aft end so they're pretty rotted anyway. I'm now worried about the hull racking with the stringers out. One person said that since it was on a roller trailer, I needed to support the hull from the aft corners with blocking and then jack the bow up and support from the keel instead of from the sides when the stringers were removed. I've also heard that it's no big deal and it doesn't need anything special since the cap is still on the boat and it's a strong transom.
So do I really need to take the time to support from the transom and keel or is ok to just leave it alone?
Thanks
Thanks
