Re: 25 hp mercury
#1 Check the linkage under the hood to make sure it is shifting into gear.
If Yes then: If no then correct the linkage problem.
#2 Mark the prop to see if the hub is spinning if the engine is shifting into gear.
If yes then rehub the prop.
Hope that helps. JR
