PiratePast40
Thread starter- Joined
- Mar 21, 2009
- 1,734
Like the title says, I ground all the way through the hull. I was trying to cut out a 6" wide piece of 1/2 " plywood they had in the bilge from just forward of the engine compartment to the transom. Thought I would just run the saw up the sides but slipped on one cut and then slipped with the grinder a few minutes later. Here's a few pictures. The cuts are about 2" an 4" long.
[/IMG]
[/IMG]
So how do I fix the holes? Cover them from the bottom with something slippery (waxed) and then pour resin and then mat from the inside? I can get to the spots from underneath to do the outside if necessary.
Thanks in advance for any help.
Oh - something else I should mention. This area is painted (?) gray and has a different consistancy than the transom and stringers. It looks suspiciously like bondo over mat. If it is, I suspect I'll need to remove all of it. Believe it or not, I can get a pry bar under it and separate it from the hull. Is it a good idea to remove all of the gray stuff covering the engine compartment bilge area?
