power trim pump diagram
buck88
i have pulled apart my power trim pump. after i pulled out the bolts that hold it togather i found 4 balls and im not sure where 2 of them go. i was wondering if anyone had the diagram for the pump. im not sure what pump it is. I will try to describe the pump if that helps. it is a metal tank with 6 bolts holding the tank to the pump plate. There are 7 screws holding the two plate together for the pump. one of the balls are larger then the other 3 balls. It has 3 springs in it with one of the spring going to a small square block with two different size pins on each side. If anyone has the diagram that would help me out so much
5150abf
Re: power trim pump diagram
Need info, what motor are you working on?
buck88
the boat has a 350 motor with a mercruiser alpha one out drive. the pump is inclosed in a round disc set up with three springs in it
ziggy
hi buck, there's a sticky post at the top of the i/o forum called adults only. go there. you should read #1.
also, you should go to #9. find the one that's applicable to you rig and download it. in it, you will most likely find pictures and specifications for what ever system it is your working on...
buck88
thanks for the iinfo so far. it seems like i have a pestolite trim pump. however the model thats in the manual has a plastic resivor and mine has a aluminum one. the pump is also a little different in the design. getting closer
