rirory
Thread starter- Joined
- Feb 20, 2009
- 69
I Am New To This Site But I Love It And I Have Learned So Much. 6 Months Ago I Bought A 19'6'' Chrysler/lonestar Aluminum Boat. The Hull Looked Perfect.
First I Rebuilt A Used Galvanized Trailer And Coated It In A Product Called Hammerite. This Stuff Is Incredible For Rust Protection. In Salt Water, Coated Trailer Springs Used Once A Month Did Not Show Rust For 3 Years--on My Bay Boat.
Next Project--rebuild The Transom--went Way Better Than I Imagined. 2 Pieces Of 3/4'' Plywood Coated With Epoxy And The Edges Sealed With Steel Flex. I Was Even Able To Modify The Old Transom Cap And Reuse It.
The Floor Had 6''-8'' Of Poured Foam As A Base For The Floor. When I Removed It, I Found Some Small Areas Of Decay. After Reading This Site And Learned Of Gluvit. Here In Florida There Is A Product The Aluminum Airboat Builders Use Called Steel-flex. I Believe It Works The Same. After I Repaired Those Areas I Launched It In A Local Canal--no Leaks---however---lots Of Oil-canning---then It Hit Me--there Are No Ribs Or Stringers In This Foolish Boat---the Foam Was It's Only Support. I Had Aluminum Stringers Made At A Machine Shop--15 For $165. I Will Be Having A Friend Air Rivet Them In Place As He Is An Amatuer Airboat Builder. Has Anyone Ever Heard Or Seen An Aluminum Boat From The Factory Without Ribs??? Supposedly Chrysler/lonestar Invented The Poured Foam Process Between The Hull And Deck.
I Will Try To Post Some Pic's But My Files Are Coming Up Too Large. Thanks To All Who Have Made This Site Such A Resource For Those Of Us Who Enjoy Projects.
