holley carb rebuild - please help
brodie123
Hi All;
rebuilding my first Holley 4150 and the needle seat assembly has me stuck. To help identify, the needle seat sits on top of both fuel bowls.
I removed the securing outer nut and the 2 small screws on the baffle plate but the needle seat does not easily come out and I do not want to force it.
Could someone please briefly describe the proper removal of the needle seat?
Thanks in advance.
CATransplant
Re: holley carb rebuild - please help
Wrong part of the forum. This is the offbreed outboard section. Try the Inboard/Outboard section with your question. Carbs discussed here have just one hole and they are sidedraft carbs for little 2-stroke tiddlers.
a70eliminator
You already removed the jamb nut now all you have to do is thread the complete needle and seat out as a unit, or actually I should say thread it in, yes screw it in as if you were tightening it then it will eventualy drop out of the bowl, this is elementary to rebuilding a holley you should get a book if you have to ask how to remove the needle and seat, you do have to remove the float assy before you can remove the need and seat.
