Re: 1708 tape vs cutting strips, which is better???
When you say 2 layers of 17oz on the transom and stringers does that include tabbing? Or would it be 2 layers of tabbing and 2 complete covers? Should I use 17oz biax or would regular cloth work? I looked at US Composites and they don't carry a 17oz cloth would 3 layers of 10oz be close enough (or would 2 of 18oz be better)?
What weight of tape did you use for your for you hull joint? I'm only finding 8.7 oz on US or 12oz biax on bateau.
Thanks for all you help Eric, I think I'm starting to get a better handle on all of this. There's just so much to learn...
My boat's a bit different from yours since it's a scratchbuild, but I can comfortably say if you use all of a 6.5 gallon epoxy kit to do your stringers and transom you've probably used too much
For my hull joints the designer specified 12 oz. tape, 2 layers overlapping on the outside, then a layer of 12 oz biax cloth, and both of these are on top of epoxy glue at the edges of the panels and the cloth layers overlap at the keel.
For your needs, I think 3 layers of 10 oz would be plenty, as would using woven roving or cloth in the same amount. Biax is easier to work with and a bit stronger for the same weight due to the fiber orientation. The critical thing is to build up the thickness you need using something other than mat. As long as there's enough thickness of oriented fibers there you'll have the strength you want. You can use 15 layers of 2 oz if you really want to.
It's up to you whether you cover the stringers completely. For the type of construction you're doing it adds some strength, but mostly just protects the stringers against abrasion and water.
Here's my suggestions for your layup with epoxy:
Stringers: Two layers tabbing, 17 oz biaxial tape. 6 inch wide then 8 inch wide. Including the mat won't hurt if you just want to order from US Composites instead of hunting around. It'll add some strength, but mostly it'll soak up extra epoxy.
Transom: Tab edges with two layers of 17 oz biax as above and cover with one layer of 12-ish oz woven cloth, overlapping all edges.
If you want to substitute plain woven cloth or roving, I'd add about 10 percent weight to match strength, so four layers of 10 oz fabric tabbing would roughly equal the two layers of biax... assuming there aren't any problems in layup.
Note that this is the layup for home builders.. it's actually overkill in strength for this use to leave some room for errors in application, unforeseen stresses, etc.
Ondarvr may have some suggestions for you too, he's mr glass
Erik
