chillin014
Thread starter- Joined
- Jan 14, 2009
- 91
I took my boat (1990 bayliner) out for the first time for a test run to make sure it would perform decently before sinking any money into it, (hence the reason for running a worn out old prop). I read that the motor should be in the manufacturers preferred RPM range at wide open throttle. Well, I could rev much higher than the recommended 5500...I'd say I could squeeze it out past 6k easily and maybe TOUCH 30 mph. It felt like for how hard the motor was working, it wasnt moving the boat accordingly (could be in my head). Holding a motor at WOT makes me feel uneasy.
So my first attempt to cure this was to buy a new prop. I dont have much of a baseline to go off of since regardless of the current props specs it is very worn out and beat. Is my train of thought correct? -That the prop is so beat that its simply not moving enough water and just spinning rather than propelling?
If this is the case I may be very pleased with the performance increase a new prop will get me. My second question is...where do people get props for these motors (1990 50 horse Force)? The options seem VERY limited...I see few on iboats website, and here and there on other websites..
