lightflyer72
- Joined
- Apr 2, 2009
- 7
I have a johnson 60 horse in which the oil injection was bypassed. The fuel still passes through the VRO and the smallest diameter hoses go from one carb to the other (don't know if this has anything to do with the issue). Once I prime the bulb and turn the key it seems that zero fuel gets to the cylinders. If I remove a plug and shoot some started fluid a couple different times it will run and stay running. If I stop the motor and let it rest for more than 10 minutes I'll have to do it all over again. What is preventing it from getting fuel in the beginning. Never once has it even tryed to fire without introducing fuel or starting fluid directly into the cylinder. Thanks
