NKG Spark Plugs - 150ETXD '90
DukesFin
I have a set of NKG plugs: BR8HS - 10
Book calls for B8HS - 10
Can I run with the "R" plugs? Everything about the plugs seem the same except for the "R" or resistor. I'm not really sure about how resistors work in plugs, so before I crank the motor with the "R" plugs in it, I thought I'd better check here first!
Thanks!
cousinabe
Re: NKG Spark Plugs - 150ETXD '90
Should not be a problem.
The difference between the two types of spark plugs is very slight. The "R" in the part number signifies an internal resister inside the spark plug, which cuts down on engine noise in the radio.
DukesFin
Thanks!
