50 hp Boggs down in the water
BassFshr
i have a 50 hp merc (no fuel pump) on the muffs it runs fine revs like it should in neutral or in gear .. get it in the water in neutral still revs like it should but in gear all i get is a good bogg at the most and cant even get close to planening out. but out of the water does fine in gear. any ideas ? ran fine last year and first time out in it today
thanks
BassFshr
Re: 50 hp Boggs down in the water
edit: just got in from doing a compression check and all 4 are almost exactly 128
BassFshr
well was a stuck needle valve.. the lower carb wasnt getting any fuel. during the process the starter slipped and knocked a green wire out that was going up to the fly wheel into a white (grommet/plug) from the rectifier? any idea how that can be repaired? does the flywheel have to come off? and any idea what the wire is? thanks again
