easy way to make a good boat
stoner_roofer
if you build the shape out of plywood (dot wory about small holes or cracks)
and cover it with IKO torch flecks base roofing material
reelfishin
Re: easy way to make a good boat
Isn't that about the equivalent of coating it in tar?
That stuff is also heavy.
If your going to make a real boat, then build it the old fashioned way, built a skeleton, then fill the seams, and paint. The wood will swell and seal itself to an extent.
If you want a cheap fishing boat, just build a section of deck out of pressure treated lumber and trap four 55 gallon barrels underneath. Seal the bungs and it will hold a ton or more.
A buddy had a bunch of floating dock sections built years ago, then used a trolling motor each year to get them in place. He often disconnected the last section and went fishing on it. It would hold about 8 people and was rock solid stable.
clarkbre
Mine is way more simple but still works great!
reelfishin
Just add a picnic table umbrella in place of a Bimini top, and it could double as a sail if the battery dies!
i'm a retire general contractor, "IKO torch flecks base roofing material" i have no idea what you are talking about.
stoner_roofer
its a big roll of black rubber when you torch it will seal together its used on flat roofs insead of tar
stoner_roofer
i used a 58 evirude 3hp and a 74 eska 4.5hp on it speed conrol was a little weird but it worked realy good and free to build cause im a roofer
Tim Frank
And the reason that it is always covered with gravel on a roof, besides ballast, is to slow the effects of UV which will eat it up pretty quickly.
But if it's cheap and easy, may not matter.
Good luck with it.
Tim Frank
Torchflex is an IKO product line....it's an SBS membrane. I doubt if the product info sheet includes use as a sealing system in boat construction.
But....if it works....:)
stoner_roofer
there is no info sheet i seen it used to cover rust on a truck and to build a shower to
rrhodes
I found an easier and cheaper way...
Shizzy
Ensign
I thought the preferred method was a layer of fiberglass cloth and a few layers of resin? Im all for saving money, but why reinvent the wheel?
