kaflanigan
- Joined
- Jul 12, 2006
- 9
Hello, I tow a Ranger 333v (17') boat with a single axle ranger trail trailer (1991). As I first start out I get a lot of trailer vibration as going over rubble strips. After about 5 to 10 minutes the trailer tows as smooth as can be. I have tried replacing the bearings (no difference) .By the way when I bought the boat the previous owner still uses the E-Z lube hub along with bearing buddies (any problem using this method, or should I just go with the E-Z lube hubs with a cap?) The tires are fairly new Carlisle 4 ply load range C ST205/75d14. Can these tires be flat spotting? But I still get the vibration after reloading the trailer after a day on the lake with the trailer sitting empty.? Anything else I should look at? Thanks
