need some help
maineiac5586
I Have A 76 Merc 500 50 Hp And Just Got It Running, Took It Out Today Seems To Run Nice. , There Is Oil Coming From The Top Of The Powerhead And Running Down Near The Carbs. I Thought The Carbs Were Lekaing But The Oil Starts Above The Carbs, Looks Like Under Flywheel? Anyone Know What To Look For? Thanks
jimg984
Re: need some help
could be a small rubber tube that runs from the bottom bearing to the top bearing has gone bad.. this tube if your motor has it is on the outside of engine. it transfers some oil from bottom to the top
maineiac5586
Re: need some help
do you think it could be a top crankshaft seal??
