firefighterco2
Thread starter- Joined
- Aug 1, 2008
- 28
I've been having some problems getting my motor to go into gear. I have replaced the control cables and adjusted them. The motor will now go into gear on the muffs in the driveway. The problem is when I put the motor in the water it will not go into reverse? I am thinking that the motor is idling too fast and that the extra drag from the water is keeping it from going into gear? On the muffs it is idling at 1500-1600 rpms.
Also there is a lot of play in the throttle linkage, is this normal?
1986 50hp johnson
1986 50hp johnson
