Hi Guys.I just got a small fiberglass flat bottom skiff.Its a 9' Whaler knock off thats in great shape except for the plywood in the transom which is badly rotted with thin fiberglass over the plywood which is inside the 1/4 inch hull.I was thinking about cutting through the thin glass and removing the plywood and replacing it with solid mahogany scribed to fit the hull and being a few pieces laid up to get the 13 1/2 width.I am a finish carpenter and could spline the wood and glue it up solid like a butcher block countertop.using Stainless hardware bolt it to the transom.I was then thinking about putting a piece of aluminum plate where my OB would go.What do you guys think,I am trying to avoid fiberglass work.
