I have a evinrude 9.9 hp 1987 and it is on a small fiberglass boat. The boat is rated for 10p max but I am having a problem with the motor performing well with two people and gear in it. The front end tends to plow and I can tell the motor is not as wound out as it is when I am by myself. How would I go about figuring out the proper prop that I would need when running all this extra weight? Any idea what the stock pitch and diameter is? If I get a new prop to make the rpms higher when loaded down and run it with just myself in there at other time, can I risk damaging the motor?
