Re: Tips on impeller change,2000 50 hp 2 stroke Merc
Get a manual it should be pretty straight forward. The one tip that I can give is on reassembly. I have a merc 125 and the manual stated to put it in fwd disassemble. When putting it back together reverse the procedure. There is more play in the forward direction then in the reverse. I would suggest putting it in reverse. I followed the manual to replace impeller. Had a good stream out of telltale and thought everything was good. Got to the marina to back my boat off and I was going forward instead of reverse. Seems like a common mistake according to the many posts on this issue. Search the threads the answers I got were very detailed by knowledgeable people. They are the ones that suggested the reverse deal and it worked out great for me. One more suggestion is the manual suggests the red locktite (nonremovable for the impeller bolts) The consensus was that, that is not a great idea. I just used the blue stuff. If you plan on doing regular maintenance on your motor you don't want to deal with hearing stuff up to remove it.
Just my 2 cents. Not an expert just letting you know what I learned the hard way.
