Re: Removing Decals
As stated heat gun best but be careful not ot melt the boat but a hair dryer works well too.
That will get the vinyl off the sticky part comes off with a little laquer thinner and some rubbing.
Used to work in a sign shop so to put them on get some masking tape, put a peice across the middle not on a letter and a peice on each end, this will help you line if up just right, when you get it lined up take the end tape off the longest side and and pull the sticker back, use a razor blade to cut the backing(don't cut through the mask on the front or you are screwed) hold the end up and work it on from the center tape to the end in a straight line with the word.
Pull the center tape off and put the rest on, take your time and don't don't try to lift it after it is stuck it will tear and if you get an air bubble poke it with the razor blade and work it out.
Good luck.
