Re: 74 JOHNSON 85 HP/ cracked coils, HELP
When no spark is seen on any cylinder, the first test is to disconnect the black and yellow kill wire from the powerpack.
As a general rule, when ignition coils are cracked, discolored, melted, or otherwise damaged, they should be replaced. A bad ignition coil on your system can kill the powerpack so it isn't worth the risk.
Ignition coils can test good over a range while failing when heated up.
On your motor, it is extremely important that the ignition coils are solidly grounded to the mounting rack, and that the mounting rack's grounding straps are in good shape and solidly grounded.
