Compression Check Numbers 9.5, 15, 25, 35Hp
Tom_C
I pick up a compression tester today to check my new to me 1982 35hp. As long as I had it I figure I test my other motors.
Are these numbers good?
1973, 9.5Hp 70psi both.
1981 15Hp 110psi both.
1982 35Hp 150psi top 160psi bottom.
1991 25Hp 115psi both.
EN2
Re: Compression Check Numbers
These numbers look good, maybe do a decarb on the 35 and test again.
Tom_C
Thanks EN2, will do.
Mas
Within 10% of each other is the rule...you're OK. A decarb may even them out.
MAS
freddyray21
the 9.5 looks a bit low to me, but if it runs good then it may be fine.
jbjennings
the 35hp actually looks too high to me. I'm wondering if EN2 is suggesting a decarb to get rid of carbon buildup that might be decreasing volume in those cylinder heads and causing abnormally high compression, and that a decarb would solve?
Just wondering,
JBJ
the 9.5 is fine, rope start if you get 60 it is good.
