unburnt fuel or oil
adam b
wen i start up my 15hp yam it spits out fuel or oil out of the exhuast i cant feel it or see it come out but you can see it hitting the water i was wondering wether it was somthing to do with the carb letting to much fuel.
cousinabe
Re: unburnt fuel or oil
sounds like it could be a ruptured fuel pump diaphragm.
post full model number.
Mas
It's probably unburned fuel/oil mixture. Check the LU just to be sure. Look for signs of water intrusion/milkyness.
If LU is OK, you might be running rich.
MAS
adam b
thanks for your replys al check the diaphram tomorrow but could you please tell me what an lu is . i dont think it is running rich because it just started a few weeks ago an it makes a right mess in the harbour
cousinabe
LU is the lower unit. Possibly leaking oil and creating a slick on the water surface.
Most common causes of oil/fuel mist on water is a torn diaphragm in the low pressure fuel pump.
Post the full model number. This helps us figure out what engine we are talking about and provides more detail.
adam b
it is a yamaha 15de 1992 i think because the letter in the corner of the tag is B
