Alpha one outdrive won't go past half up...
Insanegtp
Tilt meter shows just above half, pump acts like all up, doesn't bins, just doesn't activate, goes all the way down and back up to just over half...
havasuboatman
Ensign
Re: Alpha one outdrive won't go past half up...
Is the trim resivoir full? (Always check and fill it with the drive fully down)
Also, are you using the trim switch or the tilt button to bring it up?
Insanegtp
trailer button had loose connection.... wiggled and up...
Don S
You did fix the problem of loose connections didn't you?
