mphy98
- Joined
- Oct 20, 2008
- 1,422
just took the new old boat out for the first time today, ran great but out of the hole it started out good then the engine race like it had no propeller on it, rpms raced up, i pulled back on the throttle and eased it back up slowly and i got to speed and plane no problem, i think i did not have the lower unit all the way down as well. when i did put the unit down all the way this seemed to get rid of the problem. this is my first io so can a whale tale make cavitation happen or do you think it is because i did not have the unit all the way down. probably 85% down. 79 thundercraft 140 merc io. thanks in advance.
also had the top on as it was only 55 up here, quite noisy. should i replace that old yellow foam in the engine cover with a more modern sound deadener? and would that help that much with the noise? talking about that foil covered stuff or sound mat from best buy. thanks again bob
