TT problem
szjohnny
I own a Johnson 88 special and the tt motor is getting power thru to the brushes. Is the armature the problem?
ezeke
Re: TT problem
Lack of power is usually the problem. If the battery is fully charged, try taking the power directly to the PT&T motor with the relays removed. If that works, check the wiring.
alangf
Re: TT problem
Make sure you check the ground side of the circuit too.
