Need Help Please!!!
bryan hallahan
Bought A BOAT WITH A 71 EVINRUDE MODEL#60173C AND I AM HAVING PROBLEMS WITH IT, MAINLY THE START WON'T TURN OVER WITHOUT BYPASSING THE SILINIOD. CAN SOMEONE PLEASE SUPPLY WITH PAGES FROM THE REPAIR MANUEL. CONCERNING THE HYDRO ELECTRIC DRIVE, THE REMOTE WIRES AND THE WIRE SET UP ON THE SIDE OF THE MOTOR TO ENSURE I HAVE EVERYTHING HOOKED UP CORRECETLY. AND ANY OTHER IDEAS OR HELP WOULD BE APPREICATED. THANKS EVERYONE.
Saskatoon2005
Re: Need Help Please!!!
There is a check for the solenoid, when power is applied, you should here a click, that means it is working. No click sound means you need a new solenoid. I have offered wiring diagrams before and have been discouraged because of copyright infringement. Buy a manual for your model outboard.
chocsea
What he said......and look on the mtr or in the controls for a neutral saftey switch.....good luck
freddyray21
most starter problems are bad connections. Take all the connections loose one at a time and clean them bright.
emdsapmgr
Check the key switch for continuity in the start position. Make sure the fuse under the cowling is not blown.
Hydro Electric Shift)
(J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
