This_lil_fishy
Thread starter- Joined
- Jul 23, 2008
- 841
Okay, I won't toss them...but still...trying to figure out where they belong. When I dropped the lower unit to rebuild the water pump I found half an o-ring (about the diameter of the drive shaft), a rubber 'seal' the has drive shaft splines inside about half way down inside then ends sharp. A plastic 'seal' that is similar to the rubber one, but the splines are tapered at one end. A rubber tube (about 2") that was about half way up the copper water tube doin nothin. Then there was another rubber 'O-Ring' that was about 1/4" thick (almost like a piece of hose) on the drive shaft sitting just on top of the water pump housing.
I believe, that the plastic ring goes onto the drive shaft and mates with the tapered splines, then the rubber one goes on top of the (the outside diameter is tapered btw) with the tapered side up.
The rubber tube, I have no idea what it's purpose is, I've inserted the copper tube into the powerhead, and now it will not come out, so I guess it has a nice seal to it...althought the tube fell out when I dropped the lower unit, so I dunno (stuck in the pump).
The O-Ring, I have no idea where that came up. It's fairly thick, but it's all chewed up and half of it is missing...
The 1/4" thick 'o-ring', well it doesn't seem to suit any purpose...but I guess it's there for a reason. It didn't easily slide off the drive shaft, but definately not groove there.
Any input would be appreciated....
1986 Merc 50, 3cyl 2stroke.
Ian
Ian
