couldn't let this one get away
a70eliminator
*EdC*
Re: couldn't let this one get away
WOWSA! What a score :eek: Sometimes a man just gets lucky...
You sure did! Way to go!......... Ed
Mark_VTfisherman
If all it is is an ignition problem- Points? Stuff like that at that price should be bought just because :)
Landscaping Wiz 808
Am I to understand that you picked this motor up for $51.00!!!!!:eek::eek::eek:
Will the controls for your 60hp work on it? What kind of drive are you looking at to get to Michigan?
Congrats on a GREAT deal a70eliminator!:D
BOB
pduquette
Ensign
SSSSWWWWEEEEEETTTT
If you do as well fishing , I want to be in your boat for the tournoment !!
peter.
a70eliminator
Well after a 5hr drive I have the motor in my posession, the compression is good and I'm now in the process of swaping everything over from my 60hp to make it a long shaft, had to remove powerhead to swap longer water tubes what a pain. i'm going with the carbs off the 60 too just because they're fresh, maybe have to swap in the 80's high speed jets. My transom is torn apart right now and the motor is bolted to an engine stand it works out well.
