sheboyganjohn
Thread starter- Joined
- Aug 2, 2005
- 753
Well I had a chance to make the maiden voyage with my 1973 115 johnson on a 1972 Starcraft Capri. It ran great minus a few minor issues.
The main issue is in the shifting. Neutral is fine, reverse is fine, but when I shift into forward to the shift lock position (for lack of a better term) it does not fully shift, you can hear the gears grind and no go. Advance past the shift lock another inch or two and it will fully engage and you can back down to the lock position before going into neutral and it will stay in gear. I looked in the manual and could not find anything about adjusting the shift on it. It shifted fine on the muffs before I replaced the water pump. I do not know if the shift link eye at the top of the shift rod rotated or not. So do I need to adjust at the eye, or just the shift cable?
Another issue I that I have a lot of water spraying vertical around the motor, to the point that the sides of the motor cover are being washed. I had my passanger run the boat and I watched. The water level on plane is just below the upper plate and fully covering the cavitation plate. The motor is mounted as low as it can go on the boat. I am running one hole below the highest setting on the tilt.
Hit 35 mph with a 17 pitch hustler prop. I have a 21 pitch on order. Seemed the motor was running high RPM's. I will know more once I get the tach installed.
