minn kota edge 40lb
timdan94
does anyone know where I can find a manual for a minn kota edge 40lb thrust bow mount trolling motor?
Thanks
Dan
Re: minn kota edge 40lb
Most likely choice would be MinnKota. What do you need to know??
timdan94
I looked on minnkota website but couldn't find it. How does it release from the laying flat position?
timdan94
will 4 1/4-20 bolts be enough to mount it securely?
Wee Hooker
No experience with that series but usually the release on MinnKota's is by pulling the corded handle. This releases the stowage lock and lifts the motor in one motion. Lifting it from the deployed to stowed position is the same way.
4, 1/4" bolts are plenty strong. Just use fender washers and/or a scrap piece of material to distribute the stress evenly over your mounting area. Also use lock-tite thread sealer or nylon lock nuts so they don't vibrate loose.
timdan94
Thanks for your help. I ended up just yanking really hard on the rope to get it to release. it is now mounted and ready to go. now if only I didn't have to work 10 days straight now...
Wee Hooker
They can be a little tight but if you have to yank, a shot of lubricant is likely in order.
