Testing a Johnson esl solenoids (1972)
mars bar
Hi guys... Gals? I read and old post that talked about using a jumper wire off the starter solenoid and hook it to the green wire coming from the lower unit, should give me neutral. Then apply wire to both green and blue wires together should give me reverse. It works, Am I correct in saying that my lower solenoid is good? Prop spins in neutral but it's not in gear (safely used a piece of SM blue Styrofoam to stop the prop). I'm thinking somethings wrong with the shifter control box? Any help would be appreciated. Mars Bar. Thanks.
mars bar
Re: Testing a Johnson esl solenoids (1972)
Thank-you once again Sir.
whatknott
Another good used part source---Andre's Used Outboard Part's on e-bay stores. Or screen name--out-boards--lot's of old part's. In Canada with fast service.
