'87 Force 125- Carburator Settings?
verybayliner
Hi,
I am new to the forum.
Recently my motor has been running very rich at high speed. I can smell fuel and the performance is not very great.
I am sure that the carburators need to be adjusted. There are two carbs and I want to set them correctly. Has anyone ever done this proceedure on a dual carb?
Any ideas are appreciated. Thanks!
roscoe
Re: '87 Force 125- Carburator Settings?
you MUST start by buying a factory or a Clymer service manual.
Do NOT attempt this without a manual.
The life of your engine depends on it.
jerryjerry05
Turn the air screw in till it just bottoms out.Then turn it out 1 to 1 1/8turns out.
As far as other adjustments.The floats can be adjusted but probably won't need any adjustment.Buy a manual.Jerry
clanton
The major problem with this carb is the float needle and seat, The needle does not have a rubber TIP, the seal is inside the brass seat in the carb body. The first time the carb gets a soak in carb cleaner the seal in ruined, There is a replacement needle and seat that has a rubber tipped needle, lots of luck on finding one. If Ritt doesn`t have them, try AAA marine repair in Crystal River Fl. I do not have pn for this part.
clanton
And if you take the carbs apart, do not mix the parts, the main jets are not the same size.
verybayliner
Thank you...I think I will look into a manual.
