i originally thought that putting a drainage system in for the outside stringers would be a good idea. and now i'm second guessing myself. i was thinking that if it had a drainage system originally, then it would never get to the point of rot that i'm at now. but on the other hand, if the P/O diddn't drill holes through the hull, and if the gas line going under the deck was sealed properly then no water would have gotten down there to begin with. you also have the problem with adding a drainage system that you now leave those untouched areas succeptable to water to move in freely.
so i guess i'll get to the question, is it better to seal off those compartments and take confidence in your glassing job, or put a drainage system in? ( i plan on fully covering all stringers and the bottom side of the deck) barring no catastrophic hull damage you should never have to worry about water in there if you do a good glassing job right?
let the debate start O-o
