I have a 1996 Johnson 150 Oceanrunner and I am having an issue with it stalling. When I first start it I have to prime the bulb after each attempt. Once its started if its in neautral it will eventually die or when I go to put it in gear and just putting forward it will die. I'll check the bulb and its only about half full and need to pump it hard again. Each time I go to start I have to use the choke. If I increase the RPM's it runs beautiful and the bulb gets alittle soft. I use ethanol free gas, new gas lines and fuel water seperator, carbs rebuilt last year, no air leaks in the lines. I believe the fuel pump which is VRC is the original. Before I spend that much i would like to get an opinion if its time to change it.
