Am i running the right prop??
Status
Not open for further replies.
mtduckhunter
I have a 1984 ranger 372v with a mercury 150 black max with a 23p lazer II prop. My max speed is 53.8 MPH on GPS, With the motor trimed up with a good rooster tail, but i am running about 6000 RPM and i think i even seen the needle bouncing a few times. The boat has a jackplate with about 4 inches of setback.
Should i go up to a 24p to bring the RPMs down?
I would also like it a bit faster.
hwsiii
Re: Am i running the right prop??
I know you don't know duckhunter, but we need more information.
Boat weight, WOT RPM range recommended for motor and lower gear ratio of motor. Then we can crunch some numbers for you.
H
mtduckhunter
Well lets see, . . I think i read somewhere that the boat weighs 1200 lbs, the WOT RPM max is 5600, and i think the gear ratio is 1.87, someone correct me if im wrong, it a 1984 Mercury 150 hp black max, its new to me but this is what i have reserched.
And it is a 17', 6" boat, 7', 4" beam if that helps any.
11rufus11
Are you noticing any excessive slippage?
hwsiii
duckhunter your slip is exceedingly high at 23%.
Usually that means not enough diameter in the prop,
H
mtduckhunter
I dont know if this means anything, . . but when i run WOT trimmed up to where it should be, and the RPMs are up to at leat 6000 (thats as high as the tach reads) Shortly after it start bogging like its running out of gas, i back off the throttle and its fine.
I will try to find the diameter and let you guys know.
mtduckhunter
I checked the diameter and it is 13 1/2"
11rufus11
A 14 5/8 diameter with a 23 pitch prop would probably work for your boat, or a good starting point anyway. I believe Quicksilver Torrent or Tempest has that diameter if you want to stick with a Merc product. Expensive though.
hwsiii
Duckhunter, the first thing you need to do is check the tachometer, after you know it is correct, these are my recommendations. Change to a Laser II 13 3/4" x 25", these are numbers for that particular prop using my formulas. You will be turning right at 5,400 RPM.
I hope this helps you.
H
mtduckhunter
I was looking at the Torrent and i called a prop shop and he recommended the Tempest.
Thanks hwsiii, great info!!! i am assuming the tach is correct because the motor is idling at about 800 RPM.
Also i have noticed that the motor is mounted 5 1/2" above the very bottom of the boat, is this a little high?
hwsiii
I certainly hope you have a water pressure gauge on it. You need to know you have enough water pressure in the engine so it won't overheat, other than that it is fine.
H
mtduckhunter
No i dont have a water pressure gauge, i would like to replace my trim gauge with one.
Is there a way that i could trade my laser prop for a laser 25p like you recommended?
hwsiii
You can try calling some dealers and see if they will let you trade up.
H
mtduckhunter
I called a guy today that deals with props only and i asked him about trading and he said he didnt want a Laser!
I will try calling a few Mercury dealer.
hwsiii
I wish you luck duckhunter.
H
mtduckhunter
I lowered the motor 1 1/4", made a test run and went 57.3 (GPS) and was still climbing when it started chinewalking and i was between 5600 and 5800 RPMs.
junior1113
lot better id still look into a 24-25p good luck
mtduckhunter
Yea im very pleased!!
But i still wana go faster, so yea i think i will eventually get a 24 pitch, the tempest is the one i really want to try, not really worried about holeshot because it gets up great now, but at $500!! It will have to wait a while.
Status
