bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
I just boat a big aluminum boat . I got the tiller version because I wanted an open floor plan( small decks) but i bought the console extra to install myself. the boat still has a deck up front. I want to keep the stern as light as possible , so i want to put the batteries under the center console and the gas tank way up front.
the deck is enclosed for about 4 feet up front with the exception of the center 26" width. it is like a crawl space for storage.
I checked under some of the plastic plugs in the deck and I can see the flotation foam isnt much higher than the floor under those areas on each side under the deck.
I want to leave the center for storage and cut hatch openings in the face of the deck on either side of center to store a 6-9 gallon portable gas tanks. ONE ON EACH SIDE!!!
I need at least 12 gallons i figure. I want portable..not permanent..
I mix the oil with the gas..and i want to be able to pull the tank and empty if I have to for what ever reason.
now the delima
feeding the motor gas lines running under the flooring. Id want to run one gas can at a time( I THINK)
how can i do this?
run both to a Y fitting?
run to a shutoff switch to route one or the other to the motor?
do i just pull the quick dissconnect fitting on the empty when i go to the second tank?? and hope the O ring seals??
I have to stay with the quick dissconnect to keep the tanks portable...
but am open to ideas to feed my motor fuel and not create fuel delivery problems in the process
if you know of a product or products please tell me their name
thanks
bob
now the delima
how can i do this?
thanks
bob
