Won't Start
pinfish1
I have a 1979 2hp Evinrude, model 2902A. I have cleaned the tank, replaced the gas line taken the carb off and cleaned it but it still won't start, I'm getting spark and gas to the carb bowl?
Mas
Re: Won't Start
Test compression. Also, try shooting a bit of premixed gas down the carb to see if it will pop.
MAS
samo_ott
Re: Won't Start
Read the top secret stuff at the top of the thread on a non starting engine.
pinfish1
Re: Won't Start
The compression is not real good, it needs rings. Does the compression suck the gas out of the carb.?
Mas
Re: Won't Start
Tight cylinders is what creates the vacuum to draw fuel from the carb bowl. What are your compression numbers?
Try shooting a little oil into the cylinders to temporarily seal the cylinders and see if it will pop.
MAS
