I bought a b 19 flats boat with a 1989 150 2 stroke about 2 months ago.
Engine looks to be in great shape and ran great for 2 months. 2 weeks ago it started acting a little funny. Once the motor warms up now (after running about 15mins) it seems to go into gardian mode (I think thats what you call it) the motor will run at 1500rpms but if you push it to 2000 (Wont go more) motor feels like it will vibrate off the transom.
At first it seemed like a fuel restriction issue. Broke down and rebuilt carbs. That wasn't it. Changed out the 2 fuel pumps and of course changed out fuel filter and in line filter H2O Sep. That wasnt it.
I had a few buddies that are Yamaha mechanics (but work mostly on 4 strokes) look at it a few days ago and they were sure it was electrical. Tested the Stator and the high rpm value was only 20 and so replaced the Stator today (expensive) and at sea trial it ran better but after 15mins same thing.
Plugs seem to be burning a little wet.
Compression is 110 every cyl except 1 which reads 108..
When the problem happens and you turn off the motor and restart you can run 5-10 min before it happens again.
The oil pump was taken off (before i got it) and the valve was rigged so not to indicate low oil. I don't think this is the best way to go premix but I also don't think thats the prob.
At one point I thought it was overheating (replaced the water pump) and ran it with out the cowlin on a flat day this week. Same prob. engine was not to hot could put my hand on it for a good 2-3 min no prob. Thought maybe the alarm was bad...but that's not it.
I haven't checked the gas tank as it's glassed in on my boat but I guess my next step is to run it with a 5 gal gas can and see.
ANY HELP WOULD BE MUCH APPRECIATED.
