Morse shifter problem
true blue
I got a Parker with dual station Morse controls, two levers on each shift and throttle. My problem is the gear shift in the cabin is really hard,almost need a persuader. When I use the outside shift, everything works good, the inside shift moving along with the outside. Does anyone have any experiance with this, know the cause or fix? The throttles work ok.
Don S
Re: Morse shifter problem
Replace the cable between the front and aft helm.
true blue
If its the cable like you say why does the aft helm control move everything ok?
