jtcarter
Thread starter- Joined
- Apr 26, 2008
- 226
Alright spring is here and my rude doesn't like heat to much. It started doing the same garbage it was doing last year. I believe i've gotten to the root of the problem though. I start it up on muffs and watch the clear see thru plastic transition fitting that goes from the 3/8 hose to the 5/16 on the inside. Anyway there is a section about two inches long that you can watch the fuel go through. Well it stays solid for a minute then sucks a bubble through it. Goes solid again and just keeps repeating the process. I also notice it takes a sqeeze and a half or two to get the bulb back hard before i run to my next spot. I'm going to try a 6 gallon tank to see if the problem continues. I think it might be the pickup tube in the tank, it seems to vent fine because the bulb doesn't collapse. Puzzling thing is i've took the tube out before and checked for cracks, nothing visible. I blew through it and could not find a leak. I took the vro off once and put a fuel pump on it, it did the same thing. I know air in the fuel isn't good i got to fix this asap.
