Trouble reinstalling lower unit 9.9 1999 mercury?
DVTO2
I rebuilt my water pump and was able to get the lower unit on but then noticed the throttle/shift won't go in reverse. I pulled the lower unit off and can't figure out how to insert the shift cam so that it works properly. My SELOC manual is not much help.
DVTO2
Re: Trouble reinstalling lower unit 9.9 1999 mercury?
Come on guys. Someone must have some info on the 9.9 merc. I searched the forums and can only find threads for higher horsepower.
DVTO2
OK. I made progress. The shift rod goes in the froward part of the lower housing, with the beveled part of the cam widest at the top, sloping forward. Now I am looking for RTV silicone sealer for the back of the pump base.
Don S
Is this a 2 or 4 stroke?
DVTO2
2 stroke. serial number OD127450
I found my RTV silicone and got it back together right up the part where you latch the shift rod to the linkage in the upper housing. I appear to have pulled the linkage out of the powerhead case and am having some trouble pushing it back in.
DVTO2
OK. I got the upper housing linkage back together. There just isn't much space in there to work. Now I am hoping that I didn't reset the cam on the lower part of the shift shaft in some funky way.
Don S
If it doesn't come out right, here are the shift shaft height adjustments.
attachment.php
