17bellboy
Thread starter- Joined
- Mar 15, 2009
- 21
okay, I have a 1969 evinrude 85hp outboard. I have taken it out several times with no issues then the last time I had it out I took it out a couple miles and then shut the motor down to troll for a bit. I decided to move so fired up the main motor again and got up onto plane and went about a quarter mile when the motor just died. The only way I could get it to fire was to choke it and out of about 9 times 8 of them I'd give it throttle and as soon as I did it would die again. The other time I gave it throttle and it had no power at all, then died. So I got to come back in on my kicker. The motor fired right up to flush it and had no problems while flushing. I rebuilt the carbs assuming this was the problem. Put them back on and tried it again today. Fired right up but getting up on plane it acted like it was missing, had a lot of vibration but then cleared out and popped up on plane. I ran it at between 4000 and 5000 rpm for quite a while but as soon as I tried to go back to idle it died. Could not start it. The only time it would try to start was when choked but could not keep it running. Has a month old fuel pump on it. I replaced all fuel line in motor when carbs were rebuilt. I don't know where to go from here. It had spark in the water today when it would not run so I'm pretty sure it's fuel but where do I start?
