Hello, I have been reading thru the forum searching on the topics I noted in the thread title. Great forum here, so I signed up.
I broke the tan wire where it connects to the heat sensor (next to top plug) of my 4 cylinder electric 40 hp merc. Any idea if it is inexpensive and readily available?
If I were able to solder the tan wire back on, how do you test that the sensor is working?
Proof I am a REAL newbie - where is the engine model and.or serial no.? I see you guys often need that info here.
My impeller is going out, I think, as it only pees at fast idle, and as I lower the idle speed, the stream (very hot) breaks up, and at low idle (idle arm down) peeing stops.
I have seen conflicting statements about what gear a '95 Mercury 40 hp 4 cylinder 2 stroke must be shifted into when dropping the LU.
Any help will be welcomed.
