akwalker
Thread starter- Joined
- Jul 28, 2006
- 153
1987 OMC Cobra, 5.0 ltr. GMC, 1987 2150 Bayliner
Went out on the boat today. We were at wake speed comming into a marina for lunch, when all of the sudden there is a metallic grinding noise, and loss of forward motion. Shut down and coast into the dock. Got a ride back to our marina, fetched the trailer and loaded the boat.
Here is what I found. With the engine in forward gear, I am able to spin the prop shaft fairly easily, and can hear a metal on metal "bumping" comming from the upper (horizontal) driveshaft. So, I pull the outdrive. The splines on the yoke shaft are pretty beat up, but not completely gone. My question:
What are the symptoms of a failed motor coupler? There was no warning of the failure other than the grinding sound at the point of failure. I'm hoping that it is just the yoke shaft, and not the coupler. Any comments surely welcome.
Also, would anyone know what the diameter across the splines should be on the yoke shaft? Thanks.
__________________
__________________
