JohnMcL2000
- Joined
- Apr 26, 2009
- 8
I have recently acquired a 6hp cd24 d, a 1967 model I believe. The problem: it will start with fuel sprayed manually into the carb, but will only keep running if fuel is continuously sprayed into the carb. Here is what I have done so far:
1. Checked the fuel pump by disassembling and reassembling. All parts look good, no rips or tears in diaphragms
2. Cleaned all carb ports, including removing core plug to check low speed inlets. All clean
3. Float measured with Johnson tool, at proper level and drops within specs.
4. New fuel and oil 50:1 mix, new fuel line from gas tank to motor, new fuel line from motor fuel pump to carb.
5. All carb parts look good.
6. Lean/rich needle valve cleaned, repacked with new gaskets, gently seated then backed out one turn.
7. Good spark at both plugs, plugs clean.
Why won't this $%^@"! motor run...! Any help will be appreciated. Thanks.
