Damaged prop/tail - hit rock
PTR
New to outboard motoring - hit rock on river w/Honda 50 HP motor - slightly scrapped and bent one prop blade and clipped of part of "tail" (very bottom of motor). But works fine and turns fine. Only thing is the auto trim goes completely up and down when moving slow but when revving fast goes down all the way but only 3/4 up (is that normal operation?) and should I do something about the motor ? Thanks
kandil
Re: Damaged prop/tail - hit rock
you need a new prop and you can get a new SS skeg guard that bolts to what is left from the tail:D I don't know about he auto trim problem good luck
treebark67
there is a prop repair place in pa. called blackburns will have to look up on net or call moyers marine in selinsgrove pa they have the address and number. have had several props done by them price is half of a new prop and the work is perfect ever time
Mas
Any prop with a bent blade does not work fine...and should not be run until fixed ore replaced.
A bent blade will eventually lead to other failures. Do yourself a favor and get it fixed.
MAS
